HD Tape to dvd transfers with time code
Hi’
In the past couple of weeks I transferred roughly 73 hours worth of footage shot on a dvx-100 at 4:3 ratio…24p onto dvds with time codes so we can do our edl’s. No problem using the dvc-2500 and a dvd burner. The problem is: We had another DP shoot stuff in Italy, only they used a Sony Camera HD format 24p and it appears to be 1080. Well we purchased a Canon HV-20 so as to transfer the tapes with t/c to dvds for the project. OK so our equipment isn’t working with it and we tried capturing it to final cut 4.5 which is supposed to work with HD So finally I captured it into IMOVIE which has no option for 24p and then I turn the clips into final cut and open them there. But isn’t there a way to see the time code? Why can’t final cut recognize the camera? We need to finish two clips for the two projects to be financed…I would appreciate a simple formula since we have a great mac pro computer and we need to get this done…
Cordially
Tyler Chase
