Activity › Forums › Blackmagic Design › HD Studio capture problems with Premiere Pro 2.0
  • HD Studio capture problems with Premiere Pro 2.0
    Posted by James Orry on May 2, 2007 at 4:52 pm
    I’m running Win XP Pro with Core 2 Duo 2.66, 2GB Memory. Only one 7200rpm drive.
    Using MJPEG I was told this should be able to capture 720P, but I’m having problems with Premiere. I click capture but after a second the capture stops and asks me to save. This is happening at PAL, NTSC and 720P resolutions.
    I’ve also tried a number of drivers including the newest 6.1.
    Please help.
    Brett Howe replied 19 years, 4 months ago 2 Members · 1 Reply
  • Brett Howe
    May 11, 2007 at 5:00 am
    If you are only running one drive in your machine you are in for troubles.
    Having Premiere, your Operating system, your premiere capture and transcode files all on the one drive is not the way to go.
    Yes you can capture MJPEG to one 7200 rpm sata2, I’ve done it myself a few times, but that drive has to be free to capture, and capture only!
    Het yourself a second capture drive, at the very least.
    Cheers
    Brett
