Activity › Forums › AJA Video Systems › HD-SDI Timecode De-embedder/reader
  • HD-SDI Timecode De-embedder/reader
    Posted by Marco Solorio on March 22, 2008 at 6:02 pm
    Does anyone know of an HD-SDI de-embedder/extractor/demuxer/reader that can pull the embedded SMPTE timecode from an HD-SDI signal and spit out LTC timecode? It would be a simple little black box… SDI input (maybe with an SDI loop out) and an LTC output by means of a 1/4″ plug or BNC spigot or similarly common TC output connector.
    I’m surprised AJA doesn’t have a little “gray” box that does this… seems pretty straight forward and they’d be the company to make such a quality device.
    Searching the net for days has yielded very little results. The closest I found was this…
    https://www.evertz.com/products/8010TM-IRIG
    but at a cost of about $3350, I don’t think I’ll be going that route.
    Anyone have any idears?
    Marco Solorio | CreativeCow Host | OneRiver Media | Codec Resource Site | Cinesoft | Media Batch
    Alex Wysocki replied 7 years, 10 months ago 7 Members · 10 Replies
  • 10 Replies
  • Jeremy Garchow
    March 22, 2008 at 7:20 pm
    [Marco Solorio] “I’m surprised AJA doesn’t have a little “gray” box that does this… seems pretty straight forward and they’d be the company to make such a quality device. “
    Oh, but they do:
    https://www.aja.com/html_pop/Io_HD_bp.html
  • Marco Solorio
    March 22, 2008 at 7:40 pm
    LOL, a little overkill for a TC reader, wouldn’t you say? Key word *little* gray box! 😉
  • Rich Rubasch
    March 22, 2008 at 8:58 pm
    What about the Horita box….this takes the RS422 output of the Kona card or deck and spits out an LTC audio channel. This is how I make timecode matching dubs from HDV to DVCProHD via the Convergent designs M1 box.
    I think it is the TG-50. Horita is the timecode conversion/extraction company. Oh, and blackburst generators.
    Rich Rubasch
    Tilt Media
  • Marco Solorio
    March 22, 2008 at 9:38 pm
    Thanks, Rich. Yeah I’ve seen that unit from Horita. Unfortunately it strictly needs to be from an embedded HD-SDI source.
  • Jeremy Garchow
    March 22, 2008 at 9:41 pm
    [Marco Solorio] “Key word *little* gray box!”
    Yeah, it’s a bit bigger than little. But for around the same price as the other one you mentioned, it does so much more! 😀
  • Ramona Howard
    March 24, 2008 at 5:07 am
    Marco,
    We do this in RaveHD but it’s much bigger than a bread box 🙂 Best of luck in your quest.
    Cheers,
    Ramona
  • Jon Lewis
    March 24, 2008 at 6:14 pm
    Try this company and see if it works for you
    https://www.adrielec.com/
    Jon Lewis
  • Marco Solorio
    March 25, 2008 at 1:09 am
    Thanks Jon… I actually emailed them over the weekend! They said they might come up with such a device later this year. No luck for now though. =(
    I also emailed a couple of other manufacturers, including Markertek to see if they knew of anything… so far no response. :-/
  • Jacob Varela
    September 12, 2008 at 7:11 am
    Thank you Jon!! this is just what i need.
  • Alex Wysocki
    November 14, 2018 at 7:37 am
    This is an old thread, but I was looking into this topic and found this:
    https://www.markertek.com/product/ese-hd-491-sd/ese-hd-491-sd-hd-sd-sdi-timecode-decoder-generator
    I think it is an SDI loop that will also read the embedded time code and then convert it to LTC.
