Activity › Forums › Broadcasting › HD-SDI on ethernet cable possible?
  • HD-SDI on ethernet cable possible?
    Posted by Din Noor on March 25, 2009 at 9:58 am
    is it possible to transmit HD-SDI signal on Gigabit cables(ethernet..).Using Fibre is costlier..any suggestion..
    thks
    Din
    be calm & patience.
    Andrew Janowski replied 14 years, 8 months ago 3 Members · 3 Replies
  • Bob Zelin
    March 29, 2009 at 10:35 pm
    https://www.etslan.com/
    I will not be calm.
    bob zelin
  • Bob Zelin
    March 31, 2009 at 11:13 pm
    The answer is yes.
    HD-SDI over standard IP networks
    Pure 3 Codec by Electrosonic Products.
    888 343 3602
    https://www.electrosonic.com
    NAB booth SL9720
    is this the info that you needed ?
    Bob Zelin
  • Andrew Janowski
    February 3, 2012 at 7:36 am
    Yes you can transport HD SDI over IP , using HD high definition encoder with the HD-SDI input and IP output , HD decoder have IP Ethernet input and different video outputs  HD-SDI is one of them , but also HDMI , component ,composite video , It is nice solution too because you do not need gigabit Ethernet ,we are using Thor HD video is encoded as a 15Mbps TS , Video quality is amassing https://thorbroadcast.com/sklep-207
    https://www.thorbroadcast.com/
