Activity › Forums › Blackmagic Design › HD-SDI -> composite?
  • HD-SDI -> composite?
    Posted by Tameruk on November 2, 2005 at 1:31 pm
    Is the Multibridge capable of outputting composite video converted from an (HD-)SDI input?
    It seems to be able to output component (YPrPb) from and HD-SDI input – i thought it should do the same for composite?
    I’m using the latest (?) software v1.52
    Rob
    Tameruk replied 20 years, 11 months ago 2 Members · 2 Replies
  • Kaspar Kallas
    November 2, 2005 at 2:10 pm
    There is no composite HD signal!?
    You can only use downconverted composite
    -Kaspar
  • Tameruk
    November 2, 2005 at 2:24 pm
    Thanks Kaspar,
    That sounds fine – so after a quick search of “downconvert” in this forum i found this thread:
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=124&postid=855914
    Does anyone know if this function is likely to become available in the near future, or is there an alternative product which will do this in the meantime? Ideally we would like to use a hardware solution rather than software based…
