Activity Forums Canon Cameras HD-SDI capturing problems
  • HD-SDI capturing problems
    Posted by Todd Terry on June 26, 2008 at 6:00 pm
    Hi gang….
    Forgive the cross posting, but I may put this in a couple of forums as I’m not sure where exactly the problem lies…. Canon, Matrox, Adobe, or all of them or everything…
    Just as a test I’m attempting to do some capturing HDV source video via HD-SDI and am getting some very weird (and bad) results.
    Here are a couple of low-res clips (both the same, just different formats) to show you what I am dealing with:
    https://www.fantasticplastic.com/forum/hdsdicapture.mov
    https://www.fantasticplastic.com/forum/hdsdicapture.wmv
    And here is a full-size screen grab:
    https://www.fantasticplastic.com/forum/hdsdicapture.jpg
    As you can see I’m getting stuttery, jerky video with occassional bursts of vertical green lines.
    Ok here are the technicalities:
    Source test footage was recorded HDV 60i with a Canon XL-H1. I am using this same camera for playback outputting via HD-SDI.
    My NLE is a PC, Matrox AXIO LE, in a pretty smokin’ fast Boxx computer.
    I’m capturing within Adobe Premiere Pro v3.0.
    My Premiere project settings are Matrox – HD 1080i 29.97 fps Uncompressed 10-bit. Within Premiere I am capturing as a Matrox AVI via HD-SDI.
    I know there is no problem with the tape. If I capture as HDV video rather than uncompressed 10-bit HD video it looks fine. I only see the problem when capturing via HD-SDI, and if I record “live” footage from the camera (not on tape) via HD-SDI I still get the bad results. I have swapped out the SDI cable, with no change.
    I’m not in the best “testing situation” as unfortunately I do not have any other way to test the camera’s HD-SDI output (I do not have an HD-SDI monitor), and I do not have any other cameras, decks, or other devices that feed HD-SDI so I can’t easily test the Matrox HD-SDI input with another source.
    I can’t tell if it is a hardware, software, or settings problem…. or a combination of several.
    Any thoughts or suggestions are greatly appreciated.
    T2
    __________________________________
    Todd Terry
    Creative Director
    Fantastic Plastic Entertainment, Inc.
    Todd Terry replied 18 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
