Activity Forums Apple Final Cut Pro Legacy HD-SDI capture still broken
  • HD-SDI capture still broken
    Posted by Walter Biscardi on September 23, 2005 at 7:19 pm
    As HD-SDI capturing is still broken with FCP 5.0.2 I was wondering how this is affecting your workflow and what folks are doing as a work-around.
    For those who don’t use it, if you capture via HD-SDI, FCP will not connect correctly to the clip after it is captured. You’ll get what looks like a Subclip in the Bin and there will be no video. There are two workarounds that I know of.
    One – Remove Subclip Limits. This works ok, but still leaves about 20 seconds of bogus black at the end of each clip and the clips seem to go “offline” a lot when a project is relaunched.
    Two – Import the clips back into the project from the harddrive and delete all the subclips.
    This whole issue started with FCP 5.0 and has continued through to 5.0.2. At this point it’s really starting to become a major drag on the workflow here whenever we do HD-SDI captures. What are you doing as a workaround for this?
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
    Torrey Loomis replied 20 years, 11 months ago 2 Members · 1 Reply
  • Torrey Loomis
    September 26, 2005 at 7:50 am
    Walter,
    We haven’t seen that behavior here.
    Panasonic AJ-HD1200a deck and Sony J-H3 all going into Kona 2 via HD-SDI. Works okay for us.
    Torrey Loomis
    President – Silverado Systems
    Apple Pro Video VAR
    Apple Xsan for Pro Video Certified
    1108 Sandwick Way
    Folsom, CA 95630
    (916) 806-7189
    tloomis@silverado.cc
    https://www.Silverado.cc
    We have Panasonic DVCPRO HD and Sony HDCAM
    Check out our rates at https://www.silverado.cc/rentals.html
