Activity Forums Apple Final Cut Pro Legacy HD & SD footage in the same timeline?
  • HD & SD footage in the same timeline?
    Posted by Dom111 on June 14, 2006 at 5:37 pm
    Hi All,
    How does FCP handle HD and SD footage in the same timeline, specifically using SD footage in an HD timeline?
    Is it workable? Are there any gripes?
    Dom.
    Ramendemon replied 20 years, 3 months ago 3 Members · 2 Replies
  • Kevin Monahan
    June 14, 2006 at 5:39 pm
    Of course there’s gonna be gripes. Your footage needs to be drastically scaled up. Try Resizer for decent results. You may want to downconvert instead of upconvert.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Ramendemon
    June 15, 2006 at 2:44 pm
    I uprez SD footage to HD quite a bit. Just throw it in your timeline and scale it up to 199, then use the De-Interlace filter and set it to medium. It doesn’t look great but if the SD footage was shot well you can get away with it. If you have more SD footage than HD it’s probably best to down rez the HD, but if you have to output on HD, this is the only way I know of.
