Activity Forums Apple Final Cut Pro Legacy HD Rendering
  • Walter Biscardi
    September 26, 2005 at 4:39 pm
    [Phantom00]
    I have kona2, everytime i do digitized HD material (1080i 4:3) and wen i drag it to the time line it asked for rendering … ??”
    Your timeline doesn’t match your capture settings.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
  • Phantom00
    September 26, 2005 at 5:00 pm
    I know that the sequence setting doesn’t match the capture setting but i can only find 16:9 aspect and I do work on 4:3 .. I was asking about a plugin or something that can help
  • Jeremy Garchow
    September 26, 2005 at 5:17 pm
    Use your Kona 2 control panel and set whatever output your are monitoring with to downconvert. For instance, if you are monitoring analog component, use the control panel to put a downconvert on the analog component output. Also, change the downconvert output option to ‘crop’. That way you’ll get a 4:3 center cut of your 1080i material. If you are working in SD only, then you should digitize the HD footage into and SD format, this will take up less space, require less rendering while editing, and generally move along a lot faster.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Walter Biscardi
    September 26, 2005 at 5:19 pm
    [Phantom00]
    I know that the sequence setting doesn’t match the capture setting but i can only find 16:9 aspect and I do work on 4:3 .. I was asking about a plugin or something that can help”
    Well, how did you capture your footage? 1080i normal 16:9 aspect? Then go ahead and edit in the 16:9 timeline, but set your Kona 2 output for an SD Downconvert with a center cut (4:3) output. If you try to center cut your footage on the timeline, then yes, you will need to render every single clip.
    If you’re only working in SD, then I would suggest capturing your footage natively at 10bit SD using the downconvert option on the Kona 2.
