HD rendering in PPro CS3
Greetings, all:
I’ll keep this short and to the point. I am new to the HD world. I have a fairly new HP Quad Core computer. I import HD video files with the M2TS or AVI structure into Premier Pro CS3. Everything imports correctly, plays correctly although a bit choppy, effects and such are no problem. Here’s where the problem starts…
I save what I’ve done and press ENTER to begin rendering. It renders slowly, as expected due to large HD files. But it gets about 70% of the way and freezes. Sometimes it says “Failed to Create Movie File” or something similar. When it freezes, I have to shut down the program completely from the Alt+Ctrl+Delete method since it won’t shut itself down. What gives? I may have the settings wrong. I have tried creating a new project using both the .avi and the M2TS extensions. Same result. I am set on the 1080i60 setting of the first setup screen as well.
I should also note, this project is footage of a graduation party. It is a total of 16 minutes long. My main wedding projects will be 2 hours long. This means that I need it to be able to perform the task for a much longer project. But if it’s crashing at 16 minutes, I can only imagine the longer stuff. Can anyone PLEASE help me. I have been at it for 2 weeks to no avail. I have read the forums and can’t find anyone specifically with the same problem.
Any info would be greatly appreciated!
Thanx!
RR
Momentos PhotoVideo
