Activity › Forums › Apple Final Cut Pro Legacy › HD render times
  • HD render times
    Posted by Mick Haensler on May 22, 2008 at 10:47 pm
    I’m working on a HD project with EX 1080i footage as well as some HD jumpbacks. I’ve done simple HD projects before but this is the first time I’ve done compositing and render times for adjusting ANYTHING are huge. I have a 20 sec jumpback that every time I move it it takes 2 minutes or more to write video. Also, when I looked at the item properties it said the file was 1.1 gigs. I rendered it out of juicer as a 1080×1920 QT. Is this normal?? The render times are killing my workflow!! I’ve tried different sequence settings but to no avail. Any help would be greatly appreciated. I’m also new to FCP so I’m pretty sure I’m not doing something right.
    Mick Haensler
    Higher Ground Media
    Mick Haensler replied 18 years, 4 months ago 6 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    May 22, 2008 at 11:07 pm
    Rendered out of the juicer at what codec? Many HD codecs can be 1920×1080.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Mark Raudonis
    May 22, 2008 at 11:48 pm
    “The render times are killing my workflow!! ”
    I feel your pain. We just recently started doing HD shows and many of our interviews are done green screen. Ouch! Our renders went from minutes to hours.
    This is why you’ve got to get the latest, greatest, Octo core Mac Pros… it makes the renders manageable. My only suggestion is to either buy the latest, fastest, or deal with it. If you can’t deal with it, direct your frustration and emotion towards Apple’s “Request a feature” forum.
    Ask them for distributed rendering in FCP. If you can send FCP rendering to a render farm, that would go a long way towards making this workflow more palatable.
    Good luck.
    Mark
  • Jeremy Garchow
    May 23, 2008 at 2:42 am
    [Mark Raudonis] “Our renders went from minutes to hours. “
    What codec?
  • Mick Haensler
    May 23, 2008 at 12:33 pm
    [Jeremy Garchow] “What codec?”
    I’m working natively with the XDCAM format which is 1080×1920. I forgot to mention my machine is a 3 month old octo core with 4Gigs of ram. Will I see much improvement by adding another 4Gigs? Also, it seems my main issue is with the jumpbacks, it just seems odd to me that FCP has to re-render every time I move a HD jumpback. As I said I’m rendering the JB’s out of Juicer at 1080×1920 QT files. Should I be converting them to the EX codec and how do I do that? Again, thanks for the help.
    Mick Haensler
    Higher Ground Media
  • Walter Biscardi
    May 23, 2008 at 12:40 pm
    [Mick Haensler] “it just seems odd to me that FCP has to re-render every time I move a HD jumpback. As I said I’m rendering the JB’s out of Juicer at 1080×1920 QT files. Should I be converting them to the EX codec and how do I do that? Again, thanks for the help.”
    Yes, it will have to re-render them unless you render them at the exact codec and frame size as your media.
    If you want them to be correct for your timeline, export them as a self contained movie from FCP.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Navarro Parker
    May 23, 2008 at 2:52 pm
    Keep in mind that 1080p is almost like processing 2K film. It’s an incredible amount of pixels compared to our old SD video.
    I would suggest not editing in XDCAM, it’s an incredibly lossy format with long MPEG-2 GOP frames requires a lot of processing power. Plus its 4:2:0 color space makes it crummy for chromakey or motion graphics. I would suggest working in a format that supports 4:2:2 and only intraframe compression (like Uncompressed or ProRes).
  • Mick Haensler
    May 24, 2008 at 3:01 pm
    Thanks everyone. Appreciate the advice. Have a great weekend.
    Mick Haensler
    Higher Ground Media
