Activity Forums VEGAS Pro HD Render Issue
  • HD Render Issue
    Posted by Travis Kelly on July 7, 2010 at 7:07 pm
    Here’s my problem, When I render out video to .avi uncompressed, it is splitting my clips into multiple clips without me asking it to. If I go to render video.avi the files it renders is video.avi, video01.avi, video02.avi, etc. etc. Now I’ve just switched to a Canon t2i and My PC isnt’ the fastest, could that be the problem, It’s a P4 3ghz with 4 GB of Ram, but just a single core. I have never had this problem with Standard Definition. Any advice would be much appreciated.
    John Rofrano replied 16 years, 2 months ago 2 Members · 5 Replies
  • John Rofrano
    July 7, 2010 at 8:16 pm
    Is the drive you are rendering to formatted for FAT32 (most external hard drives are). FAT32 has a file size limit of 4GB which would cause a render to be broken up into multiple files like that. Make sure that your render drive is formatted for NTFS.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Travis Kelly
    July 8, 2010 at 12:34 am
    That would probably be the issue, is that an easy fix? can i change that without formating everything on the drive? I appreciate the help
  • John Rofrano
    July 8, 2010 at 2:24 am
    As long as there is enough free space on the drive, you can convert it. You will need to open a command prompt and issue the command:
    CONVERT X: /FS:NTFS /V
    Where X: is the drive letter of the FAT32 drive. You should backup the drive first in case anything goes wrong in the conversion process just to be safe.
    ~jr
  • Travis Kelly
    July 8, 2010 at 4:26 pm
    Never mind I got it converted, Thanks a million for the help. It’s much appreciated
  • John Rofrano
    July 8, 2010 at 6:15 pm
    You’re welcome. Glad you got it working.
    ~jr
