Activity › Forums › Blackmagic Design › HD question
  • HD question
    Posted by Craig Shaloiko on February 19, 2008 at 5:38 pm
    Hi All,
    I am needing to digitize HD footage at DVCPRO HD 720p60. However, our Blackmagic DeckLink HD card has not arrived yet. If we digitize it with our blackmagic 10bit sd card, will it down-convert it permanently even when our hd card is installed (once it arrives)?
    (—-0_o—-)
    Craig Shaloiko
    Motion Graphics / Animation
    FIREHOUSE PICTURES
    1202 N. Venice
    Tucson, Arizona 85712
    Ph: (520) 323-3151
    Fax: (520) 323-6180
    http://www.firehousepictures.com
    craig@firehousepictures.com
    Kristian Lam replied 18 years, 7 months ago 3 Members · 2 Replies
  • Del Chapple
    February 19, 2008 at 7:47 pm
    yep the sd card will only make sd video. is there a firewire output on your dvcpro hd deck?
    you cant hear my inner voice scream… can you..?
  • Kristian Lam
    February 21, 2008 at 4:56 am
    Hi, you can’t digitize with your 10-bit SD card so it is SD only and will not be able to see the 720p60 signal from your deck.
    regards
    Kristian Lam
    Blackmagic Design
