Activity › Forums › Apple Final Cut Pro Legacy › HD Quality Control????Output HD to monitor live editing
Posted by Grant Strac on August 3, 2012 at 5:36 amI recently changed jobs from HD for web to broadcast what the hell do I have to buy to hook up like a canopus box? I have a sd one but I can’t find any equivalent for HD video output to QC monitor. It’s frustrating me because I know its in my face but I can’t find device on BH.
Grant Strac replied 14 years, 1 month ago 2 Members · 6 Replies -
Shane Ross
August 3, 2012 at 7:16 amaja.com
decklink.com
matrox.com/video/en/products/Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Grant Strac
August 11, 2012 at 4:00 pmOk but I’m working with tape less system. I have a Canopus breakout for sd that just firewired in and had outputs. Do you know the best device for tape less hd editing?
Shane Ross
August 11, 2012 at 5:15 pmYour firewire options for HD are limited. VERY limited. AJA IoHD works with Final Cut Pro 6 and 7 only, and runs $3500…if you can find it. The MOTU V4HD is $2000.
If you have Thunderbolt connectors, then you have better options. Decklink Intensity Shuttle and Intensity Extreme are both under $300. The Matrox MXO2 Mini is $500. Those all work with Avid/FCP/FCX/Adobe.
If you have an iMac with no Thunderbolt…you are out of luck. If you have a laptop with Express34, there is the AJA IO Express ($1000), and Matrox MXO2 Mini. If not…if only firewire, then the first option I list is all that’s available.
What computer do you have?
Shane
Little Frog Post
Shane Ross
August 13, 2012 at 5:20 pmNo, that’s fine. Get the Decklink Intensity Pro. $200. HDMI out.
https://www.blackmagicdesign.com/products/intensity/models/
Shane
Little Frog Post
Grant Strac
August 18, 2012 at 12:00 amThank you so much for your advice. I greatly appreciate you taking the time out. Have great one man
