HD proxies for VERY old Macbook Pro workflow
Thank you in advance for reading and contributing to this post.
I’m editing a long format documentary on an iMac on Premiere Pro CS6. OS 10.7.5.
The footage is in a MPEG-2 1080p format.I am going on a trip but need to continue editing on my old Macbook. The specs are pretty bad:
2.33Gz Dual Core2 Duo.
3Gb ram (strange i know)
667 Mhz DDR2 SDRAM
OS10.6.8Is this possible? What suggestions are there (except for buying a new macbook) to make this work. I will only be doing basic edits, logging etc. but long timelines. Quick playback is important, but wont be needing to render, as this would be done again with the high res clips on the iMac. I’m hoping for a back and forth workflow to allow me to update project as I jump from one to the other.
Will the difference in OS make a difference in the premiere project?
What would be a good proxy setting, and what is an advisable workflow to implement?Thanks again!
