Activity › Forums › Apple Final Cut Pro Legacy › HD prores 23.976 timeline conversion to PAL compatible ‘equivalent’
  • HD prores 23.976 timeline conversion to PAL compatible ‘equivalent’
    Posted by Stephan Kay on May 27, 2012 at 4:20 pm
    Hello Forum
    I have a project which I shot in 23.976 (1920×1080 24p setting in Canon DSLR NTSC setting).
    I now need to screen this also in Europe (a PAL Country) on TV.
    What is the best way to convert this project? Cinema Tools? or just dump all clips into a 25p timeline and adjust each clip’s length to match the sound?
    Or does 23.976 HD 1920×1080 play back as is nowadays in PAL countries? (that would be amazing!)
    Any insight would be much appreciated.
    -SK
    Stephan Kay replied 14 years, 4 months ago 2 Members · 2 Replies
  • Don Greening
    May 27, 2012 at 7:16 pm
    [stephan kay] “Or does 23.976 HD 1920×1080 play back as is nowadays in PAL countries? (that would be amazing!)”
    You may be in luck because 24p is neither PAL nor is it NTSC. 24p is generally considered a “universal” format that is used to reach the largest possible audience. If you need to show it in Europe then contact the TV carrier who will be hosting your presentation. They will be the ones that have the final say.
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Stephan Kay
    May 27, 2012 at 9:00 pm
    Hello Don
    Thanks for your reply! I do love the sound of that for sure!! 🙂
    You made my day.
    SK
