Activity Forums AJA Video Systems HD production workflow on a budget
  • HD production workflow on a budget
    Posted by Arturo Marroquin on September 7, 2007 at 7:44 am
    Hi Gary,
    We talked briefly after the JVC seminar in Dallas. Thanks for such a great presentation–I’m sure everyone learned quite a bit. I know I did.
    Listen could ask you something? You see I have a limited budget (10-15K) to put together an HD production studio. I already own a G5 powermac (dual 2.5 GHz PowerPC with 3 GB DDR SDRAM) with FCP HD loaded, and I’m planning to purchase the JVC GY-HD110, the DR-HD100, an AJA Kona 3, and a couple of G-raid drives.
    Given my budget, is there anything else you would suggest I add to the shopping list? I’m also interested to know if you think a computer upgrade may be necessary (I read somewhere that G5s like mine are having trouble processing HD–is this true?)
    Best,
    Arturo
    Arnie Schlissel replied 19 years ago 3 Members · 4 Replies
  • Arnie Schlissel
    September 7, 2007 at 3:14 pm
    1st, you may want to raise your budget.
    You’re talking about getting a Kona card for a Mac that’s already 2 or 3 years old, and is based on PCI-X architecture. Any cards you put into this Mac will not be compatable with your next Mac. You should probably upgrade to a Mac Pro, which is based on PCI-e architecture. Don’t forget to put about 4GB (or more) of memory in the new Mac.
    You don’t mention an HD monitor. That’s going to run you another $3k-$5k.
    And I’d go with a big (as big as you can afford) SATA array rather than any firewire based drives.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Arnie Schlissel
    September 7, 2007 at 3:27 pm
    That should read $2k-$4k for a monitor. I forgot about the Panasonic plasmas, which are a very good value if you don’t need to do color correction.
  • David Roth weiss
    September 8, 2007 at 6:54 pm
    Arnie, the Pany plasmas are way less than that. The 42″ pro model can be had for only $913 at https://www.visualapex.com/plasma/plasma_details.asp?VA=Panasonic&chPartNumber=TH-42PH10UK
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Arnie Schlissel
    September 8, 2007 at 7:41 pm
    All I can say is wow! and shazam!! This is why I don’t miss CRTs!
    Arnie
