Activity Forums Blackmagic Design HD Pro and PPro 2.0 Big Problems!
  • HD Pro and PPro 2.0 Big Problems!
    Posted by Imaginate on March 7, 2006 at 2:28 am
    Can Anyone confirm this please?
    I’m having some problems with my decklink hd pro and ppro 2.0 and the latest 5.4.2 drivers:
    When editing in decklink dv pal mode i add some lower field first video with dv codec.
    It shows fine on the external monitor.
    Then i add a render from after effects lower field first video with dv codec and it’s fine on the monitor.
    Then when adding a lower third from after effects, uncompressed with an alpha channel lower field first the field order of this clip comes out wrong on the monitor! (stuttering image)
    When i repeat this in ppro with video out trough firewire it’s all fine as it should be in the first place.
    I had to deinstall the blackmagic software to be able to test this because when the software is installed my camera via firewire doesn’t work, ppro claims it’s “detected” but there is no device control and ppro claims that i need to reset the camera, the only solution is to deinstall the bm software.
    So i can’t capture at all when bmd software is installed!
    Could anyone please check this out and confirm this?
    Are you guy’s already aware of these issue’s?
    I hoped that with ppro 2.0 al the issue’s i had with this card would be lost but it seems not.
    I hope this bug’s can be solved in the near future.
    Dimi.
    Shane Chadder replied 20 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • Shane Chadder
    March 7, 2006 at 5:19 pm
    I can confirm we have the firewire capture problem as well.
    We’ve had a problem of NTSC DV fields (on an 8 bit timeline) playing correctly in realtime, but being backwards for anything rendered. I haven’t checked 2 for this but certainly 1.5.
    We also have a problem of NTSC DV footage on an 8 bit timeline going soft when titles are overlaid in 2.0. I don’t know if I’m alone on this one.
    Shane
  • Imaginate
    March 7, 2006 at 9:55 pm
    Thanks for the reply, Do you mean that when you add an effect the time that the effect lasts the fieldorder is wrong?
    I have this in the folowing way:
    When i work in a dv pal timeline captured video is ok, then when i import an uncompressed lower field first avi in the timeline the fieldorder is wrong, when i then reverse the field order it correct but then when i add for example a disolve the video stutters again on the time that the transition is used.
    The above is true for avi, is i use quicktimes that come in from cliets it’s Always wrong ! Even whwn reversing the fieldorder. This is hell because i then need to use premiere pro in the native way without the decklink card on another system to work with those files. Not a very pro look toward clients either!
    Bottmline is that when i use premiere with simple firewiredevice to previeuw, all possible file combinationa WORK, When the decklink card is involved my machine becomes “the hell of fieldorder pc”
    I often work on q clients machine who has just a firewire preview an then finetune the edit here in my studio. This workflow isnt’t possible like this for example:
    I edit a few shots and create an afer effects comp wto overlay with alpha on the clients machine, so i render out uncompressed lower field first with alpha. All works fine on the clients machine.
    Then i would take the edit home and import it in a decklink timeline, well now all ae footage has the wrong field order, this isn’t a nice way to work, i could beginning reversing all the clips fieldorders but the when i add a disolve somewhere the fieldorder is again wrong on the portions where the effect is.
    I hope this is read by people from decklink an actually fixed, i suffered from bad support for 2 years with canopus and dv storm and i hope i don’t have to go true this all again!
    Dimi.
    PS sorry for my bad english, i’m in belgium.
  • Artefact
    March 8, 2006 at 8:54 am
    i work with the multibridge extreme and do have this kind of problems too.
    here is my workflow when i do some fx in after effects:
    export out of the premiere timeline (blackmagic 10bit, no fields!!)
    import in after effects (change the field order to progressive)
    do the fx
    export from after effects (blackmagic 10bit, no fields)
    import in pp2, it works with the correct field order.
    hope this helps
    ps: my english is even worse
  • Oliver Petz
    March 8, 2006 at 4:38 pm
    Same here…
    BTW:
    The ” no field oder- progressive ” workflow is not a solution for my because the most of my key/fill material( comes on digibeta tapes, captured in upper field first mode)looks different after rendering in after effects without field order. If you ignore one Field it seems as if you are working only with the half resolution. The final Clip has always this unwanted “movie look” Animations, Typos (renderd in field order mode) are looking not so “smooth” as it should be if you ignore one of the two fields.The most footage which i have to work with comes on Sony Digibeta or Beta-SP in “Upper-Field-Mode” to me, so i have to capture and work with this two fields
    Sorry for my horrible english
    Oli
  • Imaginate
    March 9, 2006 at 3:24 am
    Hi all,
    I’m glad i’m not alone, i emailed my problems to decklink support.
    It would be great if we all did this so that they know that this are serious problems that everyone is dealing with who edit’s dv and needs to exchange files.
    thanks,
    Dimi.
  • Andrew Mcleod
    March 10, 2006 at 2:46 am
    Hi
    Firewire issue has been addressed and will be available in the next driver.
    DV on an uncompressed timeline – is currently being looked at by the developers and should have a solution soon. Hopefully today.
    The soft output of DV material on an 8 bit timeline I am having trouble reproducing. Please can you send the process to reproduce this bug and I will take a look at it.
    Andrew
    pcsupport@blackmagic-design.com
    Andrew McLeod
    Blackmagic Design
  • Shane Chadder
    March 10, 2006 at 7:23 pm
    Hi Andrew
    It is very easy to reproduce….I’m on an SDplus card at the moment, I’ll try the HDPro single link in a minute.
    1) Make a new BM-8bit ntsc timeline.
    2) Import an NTSC DV (firewire captured) clip and place it on the video track.
    3) Make a title and place it over the clip.
    4) In real time it looks fine. Now Render the title and you will see the resolution drops and the video shifts down a line at the cut point.
    It seems like any rendering causes the softness. Even just placing a transparent clip over a frame and rendering that frame you will see the difference. Especially with an HD-LInk and 24″ Dell where softness problems are easily identified!
  • Shane Chadder
    March 10, 2006 at 8:26 pm
    Same problem on our systems with HDPro single link.
