Activity Forums VEGAS Pro HD preferences for capture
  • HD preferences for capture
    Posted by Jerome Mcfadden on October 21, 2009 at 6:38 pm
    Hi fokes new to Vegas Pro 9.0b. The First program Ive used that was stable in vista 64. Any way my question is I want to do the basics capture from my Cannon HDV30 at 30 fps to watch on my Hidef tv In blue ray.. What are the Preferencs I should use for the best quality Ive already selected best but after that Im lost.Interpol whatever all the other boxes I have no Idea. These are home movies in Blue ray. Thank for any help.
    Jerome Mcfadden replied 16 years, 11 months ago 3 Members · 3 Replies
  • Terry Esslinger
    October 21, 2009 at 7:22 pm
    Do you actually plan for them to end up on Blu-Ray discs?
  • Dave Haynie
    October 21, 2009 at 7:30 pm
    Well, capture from the camcorder doesn’t change the video.. you get your 1440×1080@30p just as it’s recorded on tape, in an MPEG-2 transport stream “wrapper”.
    Fortunately, this is a supported format on Blu-Ray, so as long as you’re not building long films, you don’t really need to chance the video at all.
    You probably have to re-render… HDV is damn close to Blu-Ray format, but there’s apparently something different — DVDA doesn’t want to produce a BD without re-rendering you HDV. Different GOP structure, maybe?
    Anyway, you should create a Vegas or DDVA project at 1080/60i. Blu-Ray does support the 1440×1080 resolution of HDV as well as “full” 1920×1080, but it doesn’t technically support 30p. When you render 30p as 60i, what you’ll see on most modern televisions is effectively 30p anyway (few modern displays can actually display interlaced video anyway).
    -Dave
  • Jerome Mcfadden
    October 21, 2009 at 8:17 pm
    to answer your question I will be burning to blue ray disk. It seems all the other selections in that preferences window Im not sure about?
