Activity Forums Apple Final Cut Pro Legacy HD playout to DV
  • HD playout to DV
    Posted by Randolph Harrison on June 9, 2007 at 1:38 am
    I have a project with HD footage (1080p24). I would like to playout a sequence to a mini DV deck via firewire.
    I assume that I will need to export the sequence in some form to compressor and change it to a DV format before I “print to video”. I would also like to know if I can burn a DVD with these same settings, or would I need to do it differently.
    This former Avid editor sure could use some advice. Thank you in advance.
    Randy
    System:
    FCP 5.1.2
    G5 Quad 2.5
    4.5 Ram
    2 Cinema Displays
    3 Lacie 1T firewire drives
    Russell Lasson replied 19 years, 3 months ago 2 Members · 1 Reply
  • Russell Lasson
    June 9, 2007 at 5:31 pm
    [jrhfilms] “I would also like to know if I can burn a DVD with these same settings, or would I need to do it differently.”
    To play it out firewire in 5.1.4, yes, you would need to convert the file to DV.
    For the DVD, you need a MPEG2 file, so you would either convert the DV file to MPEG2, convert the original footage to MPEG2, or downconvert the footage to a better format than DV (ie DV50, Uncompressed 8-bit) and export it to MPEG2 from that file.
    -Russ
