Activity Forums Apple Final Cut Pro Legacy HD pixel aspect ratios
  • HD pixel aspect ratios
    Posted by Scott Van beever on April 2, 2009 at 7:17 pm
    I tried to look for an answer in the forums, but was unable to find the right one.
    I’m trying to figure out if my frame size for an HD project is 1920×1080 (HDTV 1080i), shouldn’t there be a match on the pixel aspect ratio of the same size? The highest mine goes is HD(1440×1080). When are those other ratios usable?
    *960×720
    *1280×1080
    *1440×1080
    Scott Van beever replied 17 years, 5 months ago 3 Members · 3 Replies
  • Michael Sacci
    April 2, 2009 at 7:43 pm
    HD is square when in full raster. Some codecs use different counts and aspect. What codec is your footage.
  • Walter Biscardi
    April 2, 2009 at 7:52 pm
    This depends on the format you have shot.
    DVCPro HD, HDV and even HDCAM are anamorphic formats.
    DVCPro HD NTSC and PAL have different aspect ratios.
    ProRes is full raster.
    What did you shoot and what are you delivering?
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Scott Van beever
    April 2, 2009 at 8:22 pm
    The footage is from various studios and at various rates: HDCAM 59.94i and HDCAM 23.98psf.
    But I should also mention that once finalized, the master will have to be converted for PAL. So should I be asking the studios for a clean 60i tape for an easier conversion to 50i, or does that not make sense?
