Activity › Forums › Media 100 › hd output via firewire
  • hd output via firewire
    Posted by Joyce Quick on March 12, 2008 at 6:04 pm
    how do i output 1080 hd footage via firewire. i assume i bypass the aja breakout box and just go firewire out of the mac. i have a hvr 1500 i want to go into. i can imput no problem but what is the setting to get the completed project back on tape in the deck.
    thanks
    Andrew Mehta replied 18 years, 6 months ago 7 Members · 19 Replies
  • 19 Replies
  • Floh Peters
    March 12, 2008 at 6:07 pm
    There currently is no way to output HD video over FireWire. Only SD/DV-based codecs are supported via FireWire.
  • Joyce Quick
    March 12, 2008 at 6:29 pm
    so how do i output my hd program out of my media 100hd? and record it hd on tape?
    thanks
  • Floh Peters
    March 12, 2008 at 6:30 pm
    HD-SDI
  • Joyce Quick
    March 12, 2008 at 6:50 pm
    on my hvr 1500. it has written on the ilink input hdv/dv. it says in the manual that it records to hdv via the ilink. the 1500 has a hd-sdi out but no in. help.
  • Floh Peters
    March 12, 2008 at 6:52 pm
    Does it have a HD Component in? The LHe has a HD component out you could use. Or, there are HD-SDI<->HDV converters.
  • Joyce Quick
    March 12, 2008 at 8:03 pm
    it only has sd component in. and that does not do what i want… which is to record in hdv.
    why does the hvr say it will record hdv in via ilink if you say you can’t record hdv on firewire. it definitely says that. is it because media 100 won’t send it out that way.
  • David Colantuoni
    March 12, 2008 at 8:16 pm
    Check you deck, Sony usually has add on cards for their decks that enable certain options. You deck probably outputs HD component. Media 100 does not output HDV (or any HD format) via FireWire, only through the connections provided with your AJA or HDx Hardware
    Dave
  • Floh Peters
    March 12, 2008 at 8:27 pm
    The deck will record HDV, but Media 100 will only send out SD DV-based codecs.
  • David Issko
    March 13, 2008 at 2:43 pm
    Hi Joyce,
    I too have the wonderful HVR-1500 recorder. The 1500 will only record HD (HDV) via the ilink cable/connectors so you do need to set the M100 to firewire master and set the 1500 to record HDV.
    Should work from there. Does with my M100 HDe at least. Not stated which M100 version you have.
    All the best
    David Issko
  • Joyce Quick
    March 13, 2008 at 5:50 pm
    david
    i do have the media 100 hde but when i set it to master to firewire it gives me the message “cannot master an HD program to firewire”
    how do i get around that? is it a bug?
    joyce
    ps i’m still wonder why floh said that firewire would not take hdv. isn’t that exactly how it (the hd) goes into the 1500?
