Activity Forums Blackmagic Design HD Output problems
  • HD Output problems
    Posted by Eddy Alvarez on March 29, 2006 at 8:23 pm
    hi everyone.
    we recently finished shooting a promo using the panasonic HVX200..we shot it using the 720/30p setting. after we imported them into final cut, we set the easy setup setting to the following:
    Blackmagic HDTV 720p 60 – DVCPRO HD
    suddenly the monitor says SDI No Sync. and no video plays back. oddly enough if i reset it to a 4:3 setting (like Blackmagic 8-bit NTSC) the monitor comes back to life…only the video is frozen when played back at 480i resolution and updates when at a stand still.
    ive tried fiddling around with the monitor as well as the blackmagic settings and i still cannot playback HD onto this HD monitor.
    the monitor is the Sony MEU-WX2 23″ Professional Monitor, a flat screen/LCD based monitor. with the HD/SDI option card installed.
    and that is connected to the Decklink HD Pro thru Monitoring Ouput port.
    i hope someone out there might know how to fix this.. we’ve spent quite a lot of money on these things and so far it has been a disappointing experience. 🙁
    Eddy Alvarez replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
