Activity Forums Apple Final Cut Pro Legacy HD on G5 dual 2.5
  • HD on G5 dual 2.5
    Posted by Arturo Marroquin on January 22, 2008 at 12:18 am
    I will be editing a project shot with an HVX 200 in 720p HD.
    I have a powerPC G5 dual 2.5 GHz and plan on updating the video card to an ATI Radeon X1900; will update to 5 Gigs memory, and get a Graid external drive.
    My question is: will this system be able of handling the editing in HD? And if not, what other updates do you guys suggest?
    Simon Webb replied 18 years, 8 months ago 4 Members · 11 Replies
  • 11 Replies
  • Walter Biscardi
    January 22, 2008 at 12:20 am
    I started editing HD on a G4 so you’re fine. If you plan to do uncompressed HD, you’ll need a much faster drive.
    But you can literally cut DVCPro HD on a laptop, so you’re good with the G5.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Arturo Marroquin
    January 22, 2008 at 12:23 am
    Thanks Walt,
    So then what would you suggest for my drive situation?
  • Walter Biscardi
    January 22, 2008 at 12:31 am
    [Arturo Marroquin]
    So then what would you suggest for my drive situation?”
    For DVCPro HD you’re fine. For Uncompressed HD, you need a minimum 5 Drive SATA array capable of sustaining 200MB/s throughout the array.
    We’re running MaxxDigital ProAVIO 8TB SAS/SATA arrays which run approx. 500MB/s in RAID 5.
    Read my Blog!
  • Shane Ross
    January 22, 2008 at 12:42 am
    I am editing DVCPRO HD on my Dual 2Ghz G5…still running like a champ. Using CalDigit S2VR Duo eSATA drives and G-Raid firewire drives. And I deliver HDCAM masters.
    No issues…works like a charm.
    Shane
    Littlefrog Post
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.lfhd.net
  • Walter Biscardi
    January 22, 2008 at 12:50 am
    [Shane Ross] “I am editing DVCPRO HD on my Dual 2Ghz G5…still running like a champ. Using CalDigit S2VR Duo eSATA drives and G-Raid firewire drives. And I deliver HDCAM masters.”
    Actually, thanks for reminding me. We run DVCPro HD 720 and 1080i projects on our Dual 2.0 G5 with a few LaCie S2S units. We use it primarily for documentaries and BluRay projects.
    Read my Blog!
  • Simon Webb
    January 22, 2008 at 3:46 am
    [Arturo Marroquin]
    “I have a powerPC G5 dual 2.5 GHz and plan on updating the video card to an ATI Radeon X1900”
    Before purchasing the X1900, make sure your G5 has a PCI Express slot and NOT a PCI-X slot. I almost made that mistake.
  • Arturo Marroquin
    January 22, 2008 at 5:22 am
    Thanks Simon,
    What the best way to check this?
  • Arturo Marroquin
    January 22, 2008 at 6:28 am
    Thanks Shane,
    It looks like I won’t be able to upgrade the video card. Which video card are you using on your system?
  • Shane Ross
    January 22, 2008 at 7:40 am
    [Arturo Marroquin] “Which video card are you using on your system?”
    ATI 9800 Pro. OLD card….but it is an old computer.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Arturo Marroquin
    January 22, 2008 at 7:53 am
    hey thanks Shane. Underdog rules!
    I also have an old (maybe I should use the word, ancient) system, with a PCI-only slot and an ATI 9600 XT video card.
    I want to give it a boost though–do you have any suggestions on what video card I should upgrade to, given my system’s limitations?
