Activity Forums VEGAS Pro HD on DVD5 won’t play on PS3
  • HD on DVD5 won’t play on PS3
    Posted by Chuck Manly on May 23, 2008 at 1:00 am
    Help Douglas,
    I’d like to make some HD slideshows to play on a PS3.
    What size should should the pics be to be able to Pan/Crop?
    I’m using Vegas 8 Pro.
    Can you tell me where I messed up please?
    1-Put a regular DVD 5/9 in your standard DVD burner.
    2-Edit your project in Vegas using template HD 1080-60i
    3-Tools | Burn Disc | Blu-ray disc 1920 x 1080-60i
    4-It creates an image file but does not burn to DVD
    5-Use Nero to burn iso file to a Data DVD5
    6-DVD not recognized by PS3
    7-Ask for help
    I haven’t tried using DVD Architect yet til I check with you.
    Thanks in advance,
    Chuck
    Chuck Manly replied 18 years, 3 months ago 2 Members · 3 Replies
  • Chuck Manly
    May 23, 2008 at 5:04 pm
    Update:
    The disc also failed to play in a Panasonic DMP-BD30 at Best Buy.
    Can anyone tell me their exact steps to making a DVD5 play HD files?
    Chuck
  • Douglas Spotted eagle
    May 24, 2008 at 12:33 am
    HD or HDV project properties
    Edit project
    Choose the Sony AVCHD template for 1440 x 1080.
    Select Render and Burn at top of dialog
    Hit “OK”
    That’s it.
    We don’t have a Panasonic BD player, but do have both Sony and Samsung players, discs play correctly in those. If the Panny doesn’t have updated firmware, it won’t play…
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Chuck Manly
    May 24, 2008 at 7:02 pm
    Is there a setting I need to change so I will be able to check the option “Render image and burn”?
    The “Render image only” is the only option I can check.
    I’m using a Lite-on LH-20A1S SATA internal DVD burner.
    I put the blank DVD in the player before I even open Vegas 8.
    Chuck
