Activity Forums Panasonic Cameras HD monitoring with BT-LH1700W which card ?
  • HD monitoring with BT-LH1700W which card ?
    Posted by Wim Tops on April 20, 2006 at 3:01 pm
    I have the BT-LH1700W ,the HVX200 and a Mac .
    Now I need a solution to connect the BT-LH1700W to my Mac and be able to see
    my 720pHD footage while I`m editing .
    I heard about decklink HD plus card , are there any other solutions ?
    Are there any firewire solutions ?
    David Garcia replied 20 years ago 5 Members · 5 Replies
  • Jeremy Garchow
    April 20, 2006 at 3:46 pm
    AJA Kona 2 or Kona 3 (depending on which version of the G5 you have).
    You can also go with the Kona LH or LHe (same dependencies). the Kona LH is good if you need analog input but no upconversion.
    AJA is top notch and their products just work.
    Jeremy
  • Gary Adcock
    April 20, 2006 at 4:50 pm
    [Wimpie] “I heard about decklink HD plus card , are there any other solutions ?
    Are there any firewire solutions ?”
    Note that no other cards offer the hardware acceleration for the DVCPROHD codec the Kona boards do, this can add as many as 4-6 additional tracks of video playback in realtime with the appropriate machine and fast storage. More realtime means less rendering, less waiting.
    gary
    Join us at the NAB FCPUG SUPERMEET
    Wed April 26th @ the RIO for details go to https://www.lafcpug.org/nab_2006.html
  • Wim Tops
    April 20, 2006 at 5:20 pm
    so the kona LHe would do the trick ?
  • Shane Ross
    April 20, 2006 at 7:01 pm
    Yep.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • David Garcia
    April 22, 2006 at 1:20 pm
    We are running this very system. BTLH 1700W, Kona LH, and HVX. The Card works great. Whenever I sit down to work it’s like I’m coming to my sanctuary of peaceful video editing.
    We are also using a P2 store on the ingest end which I would recomend if you have the budget.
    David
    david garcia
    Halflife* Digital
    albuquerque, nm
