Activity › Forums › Blackmagic Design › HD Monitoring via HD Link
  • HD Monitoring via HD Link
    Posted by Steve Sherrick on July 31, 2007 at 6:31 am
    For those who have come up with a workflow for this, what is the best way to calibrate your LCD monitor if you come out your Black Magic card SDI into HD Link and then DVI into the LCD. That LCD has been calibrated using a Spyder 2 Pro, but as I understand it FCP is not color sync aware. So, do I make the adjustments from the HD Link utility? I would really appreciate it if someone could provide the proper workflow for getting your monitor as close as possible for color correction using this hardware. I do understand that nothing will be as good as a professional CRT or high end LCD, but I’m unable to afford those options right now.
    Steve
    Steve Sherrick replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
