Activity Forums AJA Video Systems HD Monitoring on CRT Lacie Monitor???
  • HD Monitoring on CRT Lacie Monitor???
    Posted by Sam on May 25, 2005 at 4:47 pm
    Howdy
    So far I understand that you can purchase a Dell 24″ or the Apple 23″ + the AJA HDP unit to have a monitoring system for HD.
    Curious to find out if you could use the AJA HDP along with a CRT Monitor.
    Let’s say 19″ Lacie (or equivalent) that supports >1920×1200 resolution; get a convertor from HD15 VGA to DVI and then to the AJA HDP.
    Am I out to lunch or will that work? Have you heard or any place where you can get HD15 to DVI connectors?
    Any thoughts please?
    Sam
    Jeff Barnes replied 21 years, 3 months ago 3 Members · 2 Replies
  • Bob Zelin
    May 25, 2005 at 7:50 pm
    there are countless models of DVI monitors out there, and countless models of monitors that support 1920×1200, or lower resolution ones that support scaling.
    AJA has approved the Apple Cinema Display and the Sony SDM-P234b, and recently on this forum, John Apt from AJA stated that the Dell 2405 works as well. This does not mean that other monitors do or do not work – these are just the models that are “supported”. What that means, is that if you purchase a different monitor – it may work, it may not, but don’t blame AJA.
    The same applies for Blackmagic. I am sure there are many monitors out there that will work just fine.
    Bob Zelin
  • Jeff Barnes
    June 1, 2005 at 5:37 pm
    Does SD material look good for proper monitoring using these displays or is it only good for HD?
