Activity Forums Adobe After Effects HD monitor possibilities with AE on a budget – any thoughts?
  • HD monitor possibilities with AE on a budget – any thoughts?
    Posted by Terry Hahin on October 19, 2009 at 4:53 pm
    I’m looking for a good HD video monitoring setup for After Effects.
    I use CS4 64 with a pretty beefy PC. I don’t do a great deal of TV, and this is a first step for me into HD monitoring so I’m looking to not overkill it and go all the way.
    I definitely two monitors for computer work, this would be a third for just video preview mainly out of after effects.
    Have looked into using DVI or HDMI out of a consumer graphics card into a consumer grade panasonic HD TV, but have found scattered complaints about frame rate issues and 8-bit outputs.
    So it looks like the only solution is component out with a separate graphics card. Something even like a $1,000 blackmagic plus a $2,200 pro would be pretty rich for my blood. Again very little of my work is broadcasting at this point. But a good amount is displayed on TV’s, so I would like to have a monitoring option.
    I have also heard complaints about people having isuues with external monitors, AE, and windows XP64.
    Any thoughts? Seems like a lot of people are in my situation and can’t find a solution to this quagmire.
    Terry Hahin
    Designer and Editor
    terryhahin.com
    Terry Hahin replied 16 years, 10 months ago 3 Members · 6 Replies
  • Jan Sherlink
    October 20, 2009 at 11:55 am
    Take a look at the Blackmagic Intensity or Intensity-Pro,
    they’re quite cheap!
    I have one running quite a while now.
    Used XP64 and now on Windows7-64 connected to a Philips HD LCD.
    Running FullHD 8bit 25fps without a problem !
    cya,
    Jan
  • Jason Brown
    October 20, 2009 at 1:37 pm
    I’ve had pretty good luck with the FSI LM-1760W monitor – I think it was about 2K…
    You could use something like a Matrox MXO2 mini…and push out through HDMI, I do that occasionally for FCP and AE previews in a client’s office…it looks pretty good.
    -Jason
  • Terry Hahin
    October 20, 2009 at 8:04 pm
    Cool,
    thanks for your 2cents on this guys. These are both good options.
    Jan:
    The blackmagic intensity and consumer grade HDTV runs about 1k for 8bit through HDMI. Not too shabby for a starter option. How does it look to your eyes? Much gradient / color banding with the 8-bit output through regular HDMI?
    Jason:
    I’m checking out the matrox mini and it seems like a good product. Runs about 800 it seems, and seems very easy a mobile like you said for client work in other offices. Quick question, the matrox mini boasts 10-bit playback through HDMI, but I was under the impression that all HDMI input/output is 8-bit? Am I mistaken?
    Regardless, thanks for your two cents!
    Terry Hahin
    Designer and Editor
    terryhahin.com
  • Jason Brown
    October 20, 2009 at 8:23 pm
    [Terry Hahin] “Runs about 800 it seems,”
    That is for the Max option…which allows you to transcode (only through compressor I believe) h264 faster than real time.
    The standard I/O mini box runs around 450
    As far as HDMI and 8-bit…I have no idea, that is WELL out of my knowledge base!
    -Jason
  • Jan Sherlink
    October 21, 2009 at 8:10 am
    [Terry Hahin] “The blackmagic intensity and consumer grade HDTV runs about 1k for 8bit through HDMI. Not too shabby for a starter option. How does it look to your eyes? Much gradient / color banding with the 8-bit output through regular HDMI?”
    banding ? sure there’s banding 😉
    – it’s a bugdget solution
    – is it wrong to see banding ?
    keep in mind that -if you have the perfect setup,
    so you can view 16 or even 32bit you won’t see any banding.
    but once your file leaves your computer, the problems will arise.
    – DVD’s are 8 bit
    – Digital from cable company to Client at home is 8 bit
    – Consumer grade LCD-panels are 8 bit
    so, you’d better avoid banding to start with and see how the customer gets to see it.
    Calibrating your setup is more important than viewing in 10 bit.
    Before i start a project i’ll always ask what the final product will be…
    … and it’s never a high-end reference monitor.
    >as far as I remember, DVI was 8 bit and HDMIv1.3 extended to 16 bit sRGB
    cya,
    Jan
  • Terry Hahin
    October 26, 2009 at 7:40 pm
    Cool,
    thanks for your input Jan. I think your method sounds like the way to go, especially as a starter for HD monitoring.
    Thanks for all your help on this. Cheers!
    Terry Hahin
    Designer and Editor
    terryhahin.com
