Activity › Forums › Apple Final Cut Pro Legacy › HD lost when event imported from iMovie
  • HD lost when event imported from iMovie
    Posted by John Wade on January 4, 2013 at 6:32 pm
    I’m trying the Final Cut Pro X Trial as opposed to iMovie. I’ve imported some events that were HD but learned when I went to share with Youtube that resolution available was 960 X 540. If I Quicktime share via iMovie to my hard drive and import the movie into Final Cut Pro X I no longer have this happen. Not sure what’s up as I’m just learning.
    John
    Jeff Greenberg replied 13 years, 8 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    January 22, 2013 at 2:13 pm
    iMovie has the option of creating (conforming) projects to 960×540. For the consumer, this means their video will take up 1/4 of the space of full HD.
    Technically, btw, 960×540 is HD, defined as greater than SD (640×480).
    I’d suggest looking at the original QuickTime files – if they’re 960×540, you may have chosen this option when ingesting your material into iMovie.
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
