Activity Forums VEGAS Pro HD kbps
  • HD kbps
    Posted by Jason Warfe on April 3, 2009 at 7:56 pm
    What’s a good KBPS standard to use with HD video. When I choose “project settings” it says 25,000,000. Is that too much? If I am downgrading the footage for standard def 720×480 should I lower the KBPS to around 9,500,000?
    John Rofrano replied 17 years, 4 months ago 2 Members · 1 Reply
  • John Rofrano
    April 3, 2009 at 11:53 pm
    I assume you are talking about rendering. It doesn’t matter what format the source is, you should use a template that conform to the format you are delivering in. For an SD DVD use a standard DVD template.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
