Activity › Forums › Adobe Premiere Pro › HD issues in adobe premiere pro 1.5
Posted by Annietron on January 12, 2007 at 5:54 pmI recently started shooting HD footage, but when I tried to capture it in premiere, the video comes up choppy, with black frames (betwen normal ones) the audio is choppy.
I dont know whats wrong.
My camera is a Sony HDR-HC3, I record in 1080i, my pc is a pentium 4 2.26 G with 1 Gb of ram, and an nVidia Geforce MX 4000 and the premier pro HD plug in for the 1.5 version.I dont know what to do, please help
Is it posible to fix this with updates, or should I take the plunge and buy version 2.0??
Annietron replied 19 years, 8 months ago 5 Members · 7 Replies -
Harm Millaard
January 12, 2007 at 7:17 pmUpgrade to 1.5.1, it’s free, then check again, then consider upgrading your PC, and then consider upgrading to 2.0.
Blast1
January 12, 2007 at 8:12 pm[Annietron] “my pc is a pentium 4 2.26 G”
Like Harm mentioned you should consider a computer upgrade, your processor is under powered for HDV.
Steven L. gotz
January 12, 2007 at 8:51 pmThere is no way that PC will work for HDV. Not without purchasing Cineform Aspect HD, and even then it will be slow.
Steven
https://www.stevengotz.com -
Annietron
January 12, 2007 at 9:21 pmwow
I will considerate the pc upgrade, would yo guys recommend me the necesary upgrades plz?
Steven L. gotz
January 12, 2007 at 9:25 pm -
Payner44
January 12, 2007 at 9:48 pmIf you or a friend can build a PC yourself, this component list will do the trick for HD editing and cost well under $2000 buying online from reputatble sites like Newegg or Tiger Direct or a combination of both sites:
# Motherboard – ASUS P5B Deluxe… https://usa.asus.com/products.aspx?l1=3&l2=11&l3=307&model=1295&modelmenu=1
# CPU – Intel Core 2 Duo E6440 Conroe 2.13 GHz… https://www.newegg.com/Product/Product.asp?Item=N82E16819115004
# RAM – Kingston 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300)… https://www.newegg.com/Product/Product.asp?Item=N82E16820134384
# Hard Drive for OS installation – 1 x Seagate Barracuda 7200.9 ST380811AS 80GB 7200 RPM 8MB Cache SATA 3.0Gb/s
# Hard Drive for Video/Audio storage – 2 x Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s configured as a RAID 0 set (motherboard has onboard RAID controller for doing this)
# Hard Drive for exporting video projects (Optional, but highly recommended) – 1 x Seagate Barracuda 7200.9 ST3120813AS 120GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive
# Graphics Card – ATI 100-437750 Radeon X1650XT 256MB 128-bit GDDR3 VIVO PCI Express x16 Video Card
# DVD burner – LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM E-IDE/ATAPI DVD Burner with LightScribe Technology
# Power Supply – minimum 550 Watt with SATA connectors (for hard drives)
# Case – mid tower with USB and Firewire front panel ports (for convenience)…motherboard already has a firewire port and 4 USB ports on the backside…and have at least 3 fans in the case for cooling all that hardwareBest of luck!!
Annietron
January 12, 2007 at 11:59 pmsounds like a good inversion, I assume I’ll be able to work great with no urgent updates for a while right?
Thanx a lot guys! ^_^
