Activity › Forums › Apple Final Cut Pro Legacy › HD Ingest
HD Ingest
Posted by Scott Yun on October 13, 2006 at 8:26 pmWhen ingesting HD video into FCP, FCP wants to make a new clip every time you stop the camera. Is there a way to stop that function and ingest the video as one single clip?
Joseph Bradley replied 19 years, 11 months ago 4 Members · 3 Replies -
Shane Ross
October 13, 2006 at 9:09 pmSounds like you are talking about HDV. And if you are capturing as HDV, then no, there is no way to stop this. That is just the nature of the GOP structure of HDV.
Shane
Littlefrog Post
http://www.lfhd.net -
Chris Borjis
October 13, 2006 at 9:27 pmI just completed an HDV project that had the very problem.
The client was logging footage and wanted clips right at
the exact moment there was a scene change which caused
the batch capture to fail on about 15% of the clips.My workaround for this is:
tell your camera people to roll for at least 10 seconds
before action, and keep it rolling at least 10 seconds after
the action is done.Tell the person logging footage for later capture that
they can only log after the first 10 seconds of a scene
change and 10 seconds before the next scene.Though if they look at the footage if the shooter did
it properly, it should be obvious. -
Joseph Bradley
October 13, 2006 at 11:59 pmif it’s not HDV you can set the preset to capture through timecode breaks.
