Activity › Forums › Boris FX Particle Illusion › HD in Particle Illusion SE
  • HD in Particle Illusion SE
    Posted by Tony Mcdermott on February 8, 2011 at 8:01 am
    Hi, I have been asking around everywhere for a long time now, trying to find out how I edit WMV HD 1080p files. My computer is a: Dell Inspiron 1545. Could you perhaps send me a video showing you getting a WMV HD 1080p video file and then putting a normal emitter on it in SE and then exporting it as the exact same file but with the emitter. If you do not wish to a video then please tell me If my laptop resolution is good enough ETC, Because If I cannot do HD then I have no need for particle Illusion…
    Tony McDermott,
    Tony Mcdermott replied 15 years, 6 months ago 2 Members · 7 Replies
  • 7 Replies
  • Alan Lorence
    February 10, 2011 at 12:20 am
    If you want to do 1080 HD with SE then your laptop resolution needs to be higher than 1920 x 1080 — which is doubtful. If you want to do 720 HD, then it must be higher than 1280 x 720.
    If this is not the case, then you can’t use SE because it needs a visible window to render into (3.0 has a standalone renderer that doesn’t have this limitation)
    Alan.
    http://www.wondertouch.com
  • Tony Mcdermott
    February 28, 2011 at 10:41 am
    So if I got 3.0 my laptop would not limit me to non HD?
    (sorry im not that technical)
  • Alan Lorence
    February 28, 2011 at 3:44 pm
    It shouldn’t limit you, but download the demo version of 3.0 and give it a try. Without fully-supported OpenGL hardware, it may not work either. The demo is the only way to know.
    Alan.
  • Tony Mcdermott
    February 28, 2011 at 5:10 pm
    I have downloaded the demo, but it has still done the same thing, can you give me some directions on what to do in the software or can i not do HD?
  • Alan Lorence
    February 28, 2011 at 5:12 pm
    When you use pI3 and have a stage size that is larger than what can be rendered in pI3 itself, pIRender is launched.
    Make sure your stage size is set to the output size you want, and that you have stage zoom set to 100%. If you have both of those things set correctly, it will work.
    Alan.
  • Tony Mcdermott
    March 1, 2011 at 8:18 am
    Ok, I opened up the demo, double clicked on the add layer part (where you add what you want to put effects on) I then changed the “prefrences” and “Project settings to 1920×1080 but it still said, all the stage is not the same size as etc.. the file i chose was 1080p Hd though..?
  • Tony Mcdermott
    March 1, 2011 at 5:40 pm
    I mean 1440 x 1080.
