Activity Forums Adobe After Effects HD Frame Rate vs. Field Rate?
  • HD Frame Rate vs. Field Rate?
    Posted by Jason Connolly on June 28, 2005 at 7:53 pm
    Hello the COW!
    OK, let me apologize if this is a dumb question, but…
    I’m designing HD graphics for a client, and I asked them what the frame rate of their HD project was, and they gave me this answer:
    The Frame rate is 29.97, which is a field rate of 59.94.
    So, before I ask the client to clarify, I wanted to ask you guys for clarification(if possible). This means I deliver footage to them that is 29.97, correct? This means I set my comps in AFX to be 29.97fps, yes? I’m not sure I understand what they mean when they say 29.97fps is a field rate of 59.94.
    Any feedback welcome!
    Jason
    Jerry Witt replied 21 years, 2 months ago 3 Members · 2 Replies
  • Matt
    June 28, 2005 at 8:20 pm
    Ya, do it in 29.97fps. There are two fields per frame, hence 59.94 fields per second.
  • Jerry Witt
    June 29, 2005 at 4:25 am
    Right. When you render, set it to “fields”. The next question you should ask them is the frame size and whether they want upper or lower field first.
