Activity Forums Apple Final Cut Pro Legacy HD footage – blocky
  • HD footage – blocky
    Posted by Olly Bea on November 2, 2010 at 3:18 pm
    Hey all
    I am having a few problems with Final Cut Pro 6.0.6 for mac when working with HD footage that has been shot on EX1 cameras and converted using XDCam transfer. Basically, when I place footage onto the timeline and then place another clip alongside I am experiencing blockiness on the playback just as the two clips cut (there is no transition between the 2 clips). It also appears on the render but doesn’t always appear in the same place when I come back to the edit. Its as if the cache has been cleared (like in after effects).
    Any idea what it is and how I can get around it?
    Cheers all
    Olly
    Olly Bea replied 15 years, 10 months ago 2 Members · 2 Replies
  • Ron Pestes
    November 2, 2010 at 3:48 pm
    Is your sequence setup for the EX codec and correct frame rate? Make sure it matches your footage or you can have problems.
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
  • Olly Bea
    November 2, 2010 at 4:34 pm
    I’ve just had a look and there were some differences, so I have created a new sequence and dropped a clip into the new sequence and clicked yes to the match sequence dialogue box, I then pasted the old timeline into the new, but it still seems to be doing the same thing, again in different places.
    Any ideas?
    Many thanks
