HD: Final Cut QT >> Premiere Pro
Hi there!
The HD-Footage I shot was captured on HD on a Mac using Final Cut Pro which resulted in Quicktime-Files.
Now I need to edit these files on a PC using Premiere Pro 2.0 – while the files can be imported, they only show as a white screen when I try to play them.
They also can’t be viewed in Quicktime – neither Mac nor PC – although they can be opened and File Information is aviable, saying “HDV 1080i50” which is correct.
The question is, how can I convert the files so they can be edited in Premiere?
thanks!
