Activity Forums Avid Media Composer HD film to NTSC 48KHZ Anamorphic?
  • HD film to NTSC 48KHZ Anamorphic?
    Posted by Louis Waters on February 18, 2016 at 3:40 pm
    Hi I was told I need to convert my HD film to NTSC 48KHZ Anamorphic in Avid. How do I do this?
    I think I might have to either open an NTSC 30i project or open it in a 1080p 29.976 instead.
    Could someone run me through the steps?
    Thanks in advance.
    Louis Waters replied 10 years, 6 months ago 2 Members · 4 Replies
  • Shane Ross
    February 18, 2016 at 5:09 pm
    Create a new project…30i NTSC…aspect Ratio 16:9.
    AMA link to your file, and then transcode. OR…if you are talking about a sequence, copy the bin containing that sequence to the new project, and open.
    Shane
    Little Frog Post
  • Louis Waters
    February 18, 2016 at 7:09 pm
    Thanks! I’ve transcoded the sequence but when exporting should I use “Same as source” or use a custom width and height?
  • Shane Ross
    February 18, 2016 at 8:50 pm
    Same as source, I’d think.
    Shane
    Little Frog Post
  • Louis Waters
    February 18, 2016 at 8:55 pm
    Works perfect thank you!
