Activity Forums Adobe After Effects HD files crash on render
  • HD files crash on render
    Posted by Janis Dougherty on May 22, 2008 at 3:49 pm
    Hi there,
    Thanks in advance for your help.
    So I’m currently working on a project that is all graphics, no footage, but no major effects or 3D layeres, in a 1920 x 1080 work space.
    The specs of my computer are as follows:
    8 core Mac Pro (2 – 3GHz quad core)
    4 gigs of Ram
    OS 10.5
    and working with AE CS3
    The issue I’m running into is that when I render this file as a QT uncompressed animation, it quits about 3/4 of the way through giving me a buffering error. We fiddled with the Memory and Cache preferences.
    This isn’t the first time it happened either. Earlier in the year we were working on an HD project where I used quite a bit of 3D layers as well as Keylight. AE didn’t like it one bit. We had to render in chunks then sew it together in Avid.
    Is there a fail safe system in dealing with this sort of issue? Always well into the 6th hour after waiting all night, AE gives up and I’ve wasted a full night’s sleep.Is it just crazy to think I can render such a large file as a QT Animation, uncompressed?
    Thank you again!
    Janis Dougherty replied 18 years, 3 months ago 2 Members · 2 Replies
  • Jeremy Gray
    May 22, 2008 at 8:54 pm
    why not just render as individual frames, I was running into a crashing problem with some green screen work and I ended up rendering the individual frames as png then putting them back together. That way if i had a crash I could go to the specific frame then re-render it.
  • Janis Dougherty
    May 23, 2008 at 2:32 pm
    Thats really interesting. Someone told me that AE doesn’t even utilize more than 2 gigs of the system’s RAM at one time, no matter how much is installed . Are they delusional to think that?
    On another note, my boss who uses Avid, can render a full uncompressed HD file on 3 gigs of RAM and it plugs away with no problem. Is AE just a little more sensitive in that respect? Was it not designed to be a work horse like Avid is?
