Activity › Forums › Blackmagic Design › HD Extreme 720p60 Support
  • Joshua Helling
    February 8, 2010 at 6:40 pm
    We’ve had another customer report this and are checking into it now. Not sure when this was broken, so we are checking to see that too (or if it was always broken).
    Is this something that has never worked (if you’ve been using the card for a while) or did it work on an older driver rev and if so which?
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Steven Gage
    February 8, 2010 at 11:08 pm
    Update. So in the end the card does handle 59.94 and 60. If the source is 59.94 it will only work with a 59.94 setting. Note, Intensity Pro earlier drivers when set to 60 would handle 60 or 59.94, current Intensity Pro driver set does not allow that anymore.
    Steve
