Activity Forums Blackmagic Design HD Extreme 3 – HD to SD Down Scale
  • HD Extreme 3 – HD to SD Down Scale
    Posted by Bill Seville on October 13, 2009 at 5:52 am
    Have our footage which was shot using the Panasonic Varicam 2700 (P2) at 720p at 24fps. I may need to have this footage available in both HD and SD so I thought I would try downscaling with the BMD card. We have the HD Extreme 3 (7.3.2).
    I have contacted BMD a couple times about this with no response. Using Premiere CS4 (4.1) and thought the process was:
    -Use BMD Varicam 720p 23.976 preset in Premiere
    -In BMD control Panel, under Processing – select output processing – HD to SD Center Cut 4:3 (for example)
    -Hit save
    -Go back to Premiere and ???
    Sorry but never used before and I thought we we purchased the card, I was told it can do this. Thanks all…just trying to end up with the best footage possible both ways.
    Bill Seville replied 16 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
