Activity Forums Apple Final Cut Pro Legacy HD exporting – I love the COW!!!
  • HD exporting – I love the COW!!!
    Posted by Scott Mazarky on November 3, 2007 at 1:36 am
    My first question is, I am shooting in 720 24p and exporting using compressor (DVD best Quality 90min 16:9). Is that the best quality compressor setting for an SD DVD?
    Two, with the same HD footage, I want to be able to burn to an HD DVD or Blu-ray in the future. I shoot with P2, so I don’t have a source tape and also don’t have the space to keep the original media once the project is finished. I don’t want to lose quality by upcoverting my MPEG-2 SD finished video to HD. Here is what I was thinking. I would export a second version of my finished product using the compressor setting of uncompressed 8- or 10-bit HD. Would that allow me to burn a true HD DVD later? What would be the best setting for that?
    Paul Escandon replied 18 years, 10 months ago 4 Members · 3 Replies
  • Rafael Amador
    November 3, 2007 at 4:16 am
    If you want to get the best quality possible DVD, you should start for making the best quality possible movie.
    [Southern Video] “(DVD best Quality 90min 16:9). Is that the best quality compressor setting for an SD DVD?
    You can do better quality SD DVD. Using “Short GOPs” and “Open GOPs” while rising the data rate you can get better picture. However you must be careful with the total data rate (video+audio). You can have problems to play those DVDs in some old domestic players. In computers drivers normally they will play great.
    Rafael
    [Southern Video] “I would export a second version of my finished product using the compressor setting of uncompressed 8- or 10-bit HD. Would that allow me to burn a true HD DVD later?”
    Make a true HD DVD is not a matter of the codec that you set in your time-line. The codec will play in the quality of your master movie if is HD like if is SD. Make a HD movie and use the HD DVD settings in Compressor.
    Rafael
  • Soreyrith Um
    November 3, 2007 at 1:42 pm
    Uncompressed 8-bit HD takes up a lot more space than DVCProHD. Better to just keep it in DVCProHD.
    http://www.HotSpotsOnline.com
  • Paul Escandon
    November 4, 2007 at 12:29 am
    Howabout ProRes422 HQ? That should give you pretty darn good quality.
