Activity Forums Adobe Premiere Pro hd export to tape
  • hd export to tape
    Posted by Dave Hiebert on August 6, 2007 at 3:51 pm
    I am currently running Premiere Pro 2 on a 3.2 gig computer with an Asus P5GD2 Deluxe mb (with on-board firewire) 2 gigs of ram, 2 large sata drives, an Nvidia geForce GT 6600 video card.
    I have captured HD footage from a Canon HV-20 camera and am trying to export to tape, to master HD back to the camera. For some reason, the exporting only goes for a while and then stops…….I usually get between 5-7 minutes on tape before it quits. the camera beeps, stops and quickly flashes “check dv input” on the screen. I’ve captured hours of footage with this cable and input without as much as a single dropped frame, so I kinda doubt its a hardware issue.
    As far as i know, I have turned off all other programs, virus scanners, chat programs etc.
    Any help would be reaaaaaaaaaaally appreciated.
    Dave Hiebert replied 18 years, 10 months ago 4 Members · 9 Replies
  • 9 Replies
  • Aanarav Sareen
    August 6, 2007 at 7:15 pm
    That is a known problem with Premiere Pro 2.0 and is fixed with CS3.
    – Aanarav
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Dave Hiebert
    August 7, 2007 at 1:40 am
    Thanks for the quick reply.
    Just so I’m clear on this……….and I’m not trying to shoot the messenger here…lol, but you’re telling me that the 900 hundred dollar program that I bought to do HD wont export to hd properly, and that Adobe did not offer a patch to fix it, but fixed the problem in a later version of the program that I have to buy………..
    Hmmmmm….no wonder torrents are so popular.
    Again, thanks for the info.
  • Jeff Brown
    August 7, 2007 at 12:42 pm
    Well, to be fair, i don’t think Adobe said Pro2 did HDV export, which is what you are working with. It does do HD (uncompressed), with the appropriate hardware.
    The upgrade should be worth it for you.
    -jeff
  • Phildebougi
    October 23, 2007 at 8:12 pm
    Hello Casanna,
    I would be very much interested to know if you finally have find a method to export to tape from Premiere Pro 2 since I have exactly the same problem except that my camcorder is the Canon HV10. Thank you in advance.
  • Dave Hiebert
    October 23, 2007 at 8:51 pm
    I had to bite the bullet and upgrade to CS3. Worked like a charm after that.
  • Phildebougi
    November 12, 2007 at 10:19 pm
    Hello again,
    As you did I finally moved to CS3 and am now able to export to tape project lasting more than 10 minutes. However I am experiencing a new problem which I didnt had with CS2. I have made to-day a post to explain this problem under the title:
    “HDV project – no display in program monitor after rendering”
    I would like to know wether you too have had the same problem. Many thanks.
  • Dave Hiebert
    November 13, 2007 at 4:16 am
    I have only tried exporting to tape cuz I wanted to master the project back to the hd camera. I have not tried to render the video itself into an avi file. Is that what you’re doing? If so, what settings are you using?
  • Phildebougi
    November 13, 2007 at 12:35 pm
    In fact I was thinking that the render operation is mandatory if you want to complete a good export to tape. Incidently, what does “cuz” stand for? As a French I am laking some knowledge in day-to-day English.
  • Dave Hiebert
    November 16, 2007 at 11:50 pm
    I only export to tape and do not render all my hd stuff. I works great.
    By the way, cuz is just short for because.
    Good Luck
