Activity › Forums › Adobe Premiere Pro › HD EX-1 and H264 with DV SD edit for SD DVD
  • HD EX-1 and H264 with DV SD edit for SD DVD
    Posted by Jim Wiseman on June 2, 2011 at 8:58 am
    I am producing an SD DVD using primarily EX-1 23.98 1080P XDCam, Nikon D7000 23.98 1080P H.264, and some archival DV 720×486 29.97i SD footage. What would be the best workflow using Premiere Pro CSS5? Project and Sequence settings? Final Cut 7.03, and Media 100 Suite 1.7.1 are also installed on the machine, a Mac Pro 3.33 Ghz Hexacore with 24 Gb RAM and ATI 5870 graphics with An AJA LHi card installed. I also have an AJA ioHD and Macbook Pro, so I could do down or upconverts via SDI between those two systems to all varieties of ProRes.
    I would like the HD footage to be letterboxed and the SD footage to be full height and width for the SD DVD. It would also be nice if the same edit could also be rendered out in HD ProRes(HQ) for use as BluRay disc or for broadcast. I’m pretty sure that I will end up on an SD timeline for the DVD. It would be great if I didn’t have to do separate HD and SD edits, but if that is what is required, I could do it. Moving the HD part of the edit between the HD and SD finished versions would be advantageous.
    Any suggestions as to Premiere setup to arrive at these ends? Especially the SD version, as that is what the contract calls for. I would like to have HD and SD simultaneous monitoring.
    I am really pleased at the way Premiere handles the various formats without transcoding. Slick. I’m willing to do XML and/or media transfers between editing programs if that helps. Thanks.
    Jim Wiseman
    Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Final Cut Studio 2 and 3, Media 100 Suite 1.7.1, AJA ioHD, AJA Kona LHi Avid MC, Hexacore MacPro 3.33 Ghz, Macbook Pro Core2Duo, G5 Quadcore PCIe, Media 100i/XR
    Jim Wiseman replied 15 years, 3 months ago 2 Members · 4 Replies
  • Jeff Greenberg
    June 4, 2011 at 8:40 pm
    Do the HD edit on a 1080p timeline. Finish.
    Then:
    Make an 4:3 MPEG 2 using Adobe Media Encoder
    Make a Blu-Ray MPEG2 or h.264 using Adobe Media Encoder.
    The only other thoughts here are a question on how you’ll grab the XD cam footage. Grab it in FCP and transcode it to ProRes. Or just handle it in Premiere Pro via the Media Browser.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Jim Wiseman
    June 4, 2011 at 10:18 pm
    Thanks for the info, Jeff! Some questions:
    Should the edit timeline be 23.98 1080p? Will the SD DV material at 29.97 720x486i cause any problems? I am noticing that it comes in at a small size on a 1920×1080 timeline but I have heard there is a way to scale it up, ideally to the letterbox 1080 height for the SD DVD, if you follow me. Also will the 29.97 frame rate of the DV material cause any difficulty on a 23.98 timeline?
    Finally, should the SD DVD be kept at 23.98 fps or rendered at 29.97? I know the newer DVD players will add pulldown, but there may be some older players viewing this. It is for the state library system and public schools, so it needs to be as compatible as possible. Broadcasters (local PBS in Hawaii) use 29.97 1080i as well, don’t they? I believe the BluRay can be either frame rate as they can add pulldown.
    Thanks so much for your help!
    Jim Wiseman
  • Jeff Greenberg
    June 4, 2011 at 10:29 pm
    Yeah, in thinking it through, I’m a little wrong on the prior post.
    I think you’ll need two timelines: I’d cut the HD one, scaling up the SD clips (you’ll have to do those manually, else they’ll be ‘pillar’ boxed.)
    When finished, I’d suggest copy/pasting the entire timeline into an SD timeline, and then choosing the “scale to sequence”) with all the clips selected. All the HD clips will be scaled down (and letterboxed) while the SD clips will return to their normal size.
    Both SD DVDs and BluRay can handle 24 material correctly for playback – Older DVD players handle the playback too – but if you’re worried, why not just build the SD timeline @ 29.97? I’m pretty sure the 23.98 is part of the original spec – meaning it should be compatible.
    [Jim Wiseman] ” I am noticing that it comes in at a small size on a 1920×1080 timeline but I have heard there is a way to scale it up, ideally to the letterbox 1080 height for the SD DVD,”
    Yup, Premiere Pro handles everything (by default) as a mapping of 1:1 pixels – you can scale it up manually (which is what you want for the SD in the HD sequence). There’s a cool “Scale to sequence size” choice, but it’ll pillar box.
    Disclaimer: don’t trust me or anyone else here; test this yourself with 30 sec-1 min of footage and be sure.
    Best,
    Jeff G
  • Jim Wiseman
    June 4, 2011 at 10:33 pm
    Thanks Jeff! I’ve really been beating my head against this one!
    Jim Wiseman
