Activity Forums Compression Techniques HD encoding solution on Mac?
  • HD encoding solution on Mac?
    Posted by Dolby411 on December 9, 2005 at 3:18 pm
    Hello all,
    The production house I work at needs to deliver a video for a museum in the following specs:
    1080i
    MPEG2 transport stream
    50-60 Mbps
    Currently we have the Optibase MPEG Master SDI encoder running on a Mac which we also use to author DVDs in DVDSPro. I’ve been doing some research, and I can only find PC solutions that will encode at the parameters above. Does anyone know any solutions on a Mac – hardware, software? I’d like to keep the authoring station we have now and just put a new encoder card in. But if that’s not the case, what on the PC side would be recommended and what DVD authoring programs are “good”. Sorry for the weighted question – thanks in advance for the response.
    Dolby411 replied 20 years, 9 months ago 2 Members · 2 Replies
  • Ben Waggoner
    December 9, 2005 at 9:38 pm
    DVD is HD, and you’re specing a HD file format.
    I’ve been using Rhozet Carbon (Pro ProCoder) for my HD MPEG-2. However, it only does .ts files with MPEG-2 Layer II audio. If that’s not a problem, it’s probably perfect for you.
  • Dolby411
    December 9, 2005 at 10:00 pm
    Thanks for the response Ben. Sorry about my thoughts being rambly, but we will be delivering HD MPEG2’s on hard drives. We won’t be authoring these to DVDs at all. So does the Rhozet Carbon (Pro ProCoder) encoder create MPEG2 files? And does that run on a PC? Does anyone know of a Mac solution?
