hd editing, system settings, rendering issues
I’m new to hd editing, I have unwrapped mxf files from an external hard drive using import from p2, I set easy setup to dvcpro hd 720p60 as the same settings given in the footage properties. when I drop the clip into the sequence it shows it needs to be rendered and re-rendered each time it is moved above another clip, It also seems to lose a lot of quality and becomes interlaced when entered into the sequence. please help
