Activity › Forums › DVD Authoring › HD-DVD with 60 frame per second in MPEG-2
  • HD-DVD with 60 frame per second in MPEG-2
    Posted by Kinthy on February 6, 2006 at 7:44 am
    hi all,
    try to export a MPEG-2 with FCP with compressor, there have no choice of 60 fps for HD-DVD, it only limited to 30fps.
    Is it the standard of HD-DVD have 60fps? If yes, can FCP with compressor can export that kind of file?
    Please give advice, thanks.
    kinthy
    Chris Borjis replied 20 years, 7 months ago 2 Members · 3 Replies
  • Chris Borjis
    February 6, 2006 at 5:10 pm
    I don’t think you can do an HD-DVD at 60fps. Just 30 or 24 with drop or non-drop.
    If your video is indeed 60fps, try dropping it in a 29.97 or 30fps
    timeline then render that out.
  • Kinthy
    February 7, 2006 at 1:54 am
    hi all,
    Is it HD-DVD /w 60 fps is not a standard?
    any solution can produce the HD-DVD /w 60 fps 1080?
    please give advice, thanks.
  • Chris Borjis
    February 7, 2006 at 4:54 pm
    No its not a standard.
    It follows the same specs as blu-ray for defined content paramaters.
    no 60fps.
    convert your 60fps video to 30.
