Activity Forums Blackmagic Design HD downconvert not working
  • HD downconvert not working
    Posted by Helgi Thor on June 5, 2009 at 5:28 pm
    I have a Decklink HD Pro in a PC with Premiere Pro CS3. Component analog works fine, but when I attempt to output from an HD project the video is scrambled. I’ve set the Output processing to ‘HD to SD Letterbox 16:9’
    Do I need a tri-level sync for this to work or could it be something else?
    Helgi Thor
    Editor
    Fortaleza
    Brazil
    Helgi Thor replied 17 years, 3 months ago 2 Members · 2 Replies
  • Anthony Dalesandro
    June 5, 2009 at 11:40 pm
    I had the same problem. Is your project 720 60? The card can’t do on the fly downconverts from that format.
    Anthony Dalesandro
    anthony@anthonydalesandro.com
    https://www.anthonydalesandro.com
  • Helgi Thor
    June 8, 2009 at 3:27 pm
    It was actually 720 23.976, but I tested 720 60i as well. Just did a test with a 1080 project and apparently it’s working as expected, but a bummer not being able to monitor/output from a 720 project.
    Thanks for your help.
    Helgi Thor
    Editor
    Fortaleza
    Brazil
