Activity › Forums › Blackmagic Design › hd downconvert
  • hd downconvert
    Posted by Paul Provost on June 9, 2006 at 3:34 am
    I’ve got a client that wants to downconvert an HD 720p 23.98 file to digibeta.
    We’ve got Decklink Extreme systems. All Mac – with latest OS, FCP and BMD drivers.
    from what I can tell this is NOT supported. am I right?
    any way around this? (frame rate conversion plugins etc.)
    thanks
    Paul Provost replied 20 years, 3 months ago 2 Members · 3 Replies
  • Paul Provost
    June 9, 2006 at 4:48 pm
    need to give client answer today
    please help!
  • Kristian Lam
    June 10, 2006 at 8:51 am
    Hi Paul,
    We support down conversion for 720p59.94 to NTSC. However, try using the NTSC 23.98 easy setup that we provide. This will do real time pull down to NTSC (29.97) when you play out. You’ll have to render your 720 sequence to NTSC, but the frame rate should be the same (23.98).
    regards
    Kristian Lam
    Blackmagic Design
  • Paul Provost
    June 11, 2006 at 2:42 am
    thanks Kristian!
    I’ll give it a try Monday, if the client still needs it
    Paul
