Activity Forums Apple Final Cut Pro Legacy HD Doc for NatGeo, advice needed
  • HD Doc for NatGeo, advice needed
    Posted by Rob Alexander on February 6, 2008 at 6:29 pm
    Can I get some advice on what will be my first proper HD job.
    It’s a documentary for National Geographic in the States and the producers are planning to shoot it on an F900.
    We’re UK based and used to PAL and 25 (50i) so bear with me here! It should be 1080i and 59.94 on tape so I have to figure out the best way to edit it. My rig is a bit older but it’s solid and does the job well however I figure I’m probably going to need to do a bit of upgrading. At the moment it comprises of G5 Dual2ghz, 3GB ram, OS10.4.10, FCP 5.1.4, Decklink extreme (SD)
    The options it seems are to:
    1) offline in SD from a downconverted output from a JH3 – great from a hardware point of view but don’t much fancy the autoconform, FCP has a habit of screwing up especially if you have a lot of speed changes.
    2) offline (online) in DVCPROHD. I like this one, although I’ll need a new capture card I can digitize once, edit the thing then play out to HDCAM for grading and final online. But is DVCPROHD acceptible?
    3) offline (online) in prores422. Not sure about this as even with a new card (unless it’s IOHD) I don’t know whether the Mac will be up to it. Otherwise I suppose it has the same merits as DVCPROHD. Again is Prores acceptible to NatGeo?
    I should also mention that I plan to duplicate the media so that I can cut at home as well as in the office on another G5 with decklink in – I can live with a downconverted SD output there!
    Whatever happens I expect I’ll upgrade to FCS2.
    I’d really appreciate any advice on this one.
    Rob
    Jorge Rojo replied 15 years, 9 months ago 6 Members · 7 Replies
  • 7 Replies
  • Aaron Neitz
    February 6, 2008 at 6:41 pm
    I’d recommend offline at DVCPRO-HD. Small file sizes, the G5 can readily handle it, it will look great for editing.
    Then recapturing for your final will be very easy – no transposing of timecodes. Also, depending on the intensity and production level of the project, you might be able to deliver DVCPRO-HD laid back to HDCAM for final. That’s a network quality control question, but a lot of them will accept it.
    I don’t think a dual G5 can handle ProRes. It’s very processor intensive. Having said that ProRes HQ is phenomenal – you’d be very hard pressed to tell the difference between it and uncompressed HD.
    Personally I wouldn’t sweat the move to FCP6. In many ways 5.1.4 is more stable and less buggy. I did a lot of HD work on my G5 with 5.1.4 and it never let me down.
  • Aaron Neitz
    February 6, 2008 at 6:43 pm
    Also… chances are they’ll shoot 1080/24. Which is great for editing. You need to deliver a 1080i/59.94 tape, but all that means is adding standard pulldown to the final layoff.
    This is something to confirm with the producers and whoever has delivery specs, but it’s more likely than anything else.
  • David Roth weiss
    February 6, 2008 at 6:44 pm
    Rob,
    With the addition of a Kona LH your machine is perfectly suited for cutting DVCProHD, but cannot capture Pro Res. So, the best and easiest workflow is to digitize to and cut in DVCProHD, and then output back to HDCAM. One slight enhancement for titles and graphics would be to render the final timeline with the Pro Res HQ codec before outputting to HDCAM, which would be preferable to DVCpro compression. That step would do nothing for the video, but would keep the graphics and test in a close to pristine state, and still be playable on an inexpensive raid or even on firewire 800 hard drives.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Jamie Pickell
    February 6, 2008 at 6:49 pm
    Rob,
    I work at Nat Geo as an editor cutting on FCP. They shoot most of their programming on DVCProHD so you can edit in DVCProHD and not have to worry about the autoconform issues. Hold off on the ProRes422 workflow because I don’t know if the client has come to a decision on its acceptability. If you want me to put you in touch with some here who can answer your questions directly, contact me offline.
    Jamie
    Dual 2.5 G5
    10.4.10
    FCP 5.1.4
    XRaid
    Kona 2
    jpickell@ngs.org
  • Rob Alexander
    February 7, 2008 at 1:34 pm
    Thanks for the posts everyone. DVCPROHD sounds like the way to go assuming that there aren’t any tech issues going from one compressed HD format to another (albeit via HD-SDI). I’m sure I read somewhere that there’s a 1920×1080 setting for DVCPROHD in Final Cut, is that right? or would I just capture using an easy setup to 1280×1080 and let the Kona do all the scaling?
    Cheers
    Rob
  • Walter Biscardi
    February 7, 2008 at 1:47 pm
    [Rob Alexander] “‘m sure I read somewhere that there’s a 1920×1080 setting for DVCPROHD in Final Cut, is that right? or would I just capture using an easy setup to 1280×1080 and let the Kona do all the scaling?”
    Nope, that’s ProRes. Let the Kona do the scaling as it does this perfectly.
    In PAL, the scale might be 1440×1080 so don’t be surprised if that’s the case.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Jorge Rojo
    December 9, 2010 at 12:45 am
    Hello Mr. Alexander, I am posting you this message from México, I would like to make contact with you to talk about a document that you and/or your team might be interested in for a documental story. With regards: Jorge Rojo.
